by samuellaw178 on Fri Feb 03, 2012 11:37 am
Darin, honestly, me think you're imagining a little too much. From doubting your Silvia temperature, to pressure, then to your grinder and now your beans.
As mentioned, beans need a slight grind tweaking as they age. To properly extract the flavors, the usual flow rate is needed. If they're too coarse, grind finer or updose if you can without hitting the screen.
Upload a video of the extraction if you will. This way, many experienced people here can give better advice of what went wrong. It's better than to shoot in the dark. Sometimes there're critical factors that you missed that might be caught in the video.
