I'm not sure I've described all of this clearly enough.
I remember hearing or reading somewhere that Godfather contains Robusta. It consistently has more caffeine than the Rocket Brand. That's not in question.
What I have noticed is that, the Rocket Brand seems to have significantly more caffeine than usual. To give some background, when I order the Rocket Brand, I get 5lbs (within 3-4 days of roasting), and I freeze it according to the instructions I've read here (tape over the 1 way valve, place bags in a ziploc, place at the bottom of the deep freeze, and defrost a week's worth at a time.). The last shipment I received seemed to have far more caffeine than usual, on par with the Godfather blend.
Since it takes nearly a month for me to use up all 5 lbs, this observation was not made based on one afternoon's consumption, but over a month of drinking the coffee. Clearly, this past month the coffee seemed to be more caffeinated than previous months (Remember, this batch had a chance to age much longer than usual). Therefore, I think it's safe to rule out things like stomach contents, and other short term fluctuations.
As I admitted before, it's more plausible that the effects are the result of a change in the blend, or other factors that may be affecting me personally (I have been under a lot of stress lately. A few months without playing any gigs has meant very little income, and has left me wondering whether it's time to find a day job again.).
Nonetheless, I posed the question as a matter of curiousity.
another_jim wrote:AFAIK, caffeine is chemically stable, while the flavor compounds oxidize. So conceivably, the amount of caffeine per unit of taste would rise with age. However, I don't know if such a ratio makes sense.
This is precisely my question. Thank you for wording it much more ably than I did.
"Does the amount of caffeine per unit of taste rise with age?"
"There's a fine line between hobby and mental illness." - Anon.
LMWDP #326
