An unmodified Sivetz is one on which you have no genuine granular temperature or airflow control apart from using a gate valve to reduce the amount of gas coming into the burner. At best this allows you to extend an 8 minute roast to about 11 minutes. I refer specifically to the 1/4 bag machine as I have no experience with other sizes of Sivetz roasters although I have worked on both 1995 and 2006 vintage machines (former has burner in an attached chamber and latter uses an external Midco burner that fires into a funnel from a short distance away.) If doing multiple back-to-back roasts the 11 minute time can drop to about 9:30 when the unit gets really hot.
Subsequent to working on the Sivetz (which belonged to a cafe for whom I worked part time) I owned and roasted on a Diedrich IR-12. In my limited experience the Sivetz roasted coffees tended to have a brighter profile that seemed a bit more acidic. This characteristic was actually a benefit with the Indonesian coffees I roasted, was a neutral factor with the Centrals (I only had a chance to roast Guat and El Salvador) and IMHO it was a slight shortcoming when roasting some African coffees (Yirgacheffe and Tanzanian Peaberry in particular - the Kenyan AA did much better on the Sivetz.)
The shortcoming was the lack of any capability for slowing down the ramp up to specific target temperatures at various points in the roast. My results were very consistent but not always optimal based on my taste in coffee. I slowed down roasts with the gate valve and also allowed the unit to cool down a bit after every X number of batches in order to be able to keep my roasts at 10 to 11 minutes. The person who took over my roasting responsibilities for that cafe does not use the gate valve to extend roasts as I did and more than a few of my former customers have commented that they enjoyed the coffee I roasted more than what they are drinking there now.
With the Diedrich the option to control temperature rise and profile is much better but that machine is very particular when it comes to cleanliness of the airflow path. Any deviations from a strict and regualr cleaning schedule for all parts and pieces in the air pathway can result in a smokiness or "roast flavor" in the profile (I know as I have experienced this and others who tasted some of my Diedrich roasted coffee detected this on certain batches.) This is not a shortcoming of drum roasters - it's simply a characteristic of that machine and can be overcome by good maintenance procedures. I've had stellar coffee roasted on an IR-12 - some of my own and also from both Victrola and Ecco. I've also had some great coffee roasted on fluid bed machines.
Is there room for both drum roasters and fluid bed roasters in the same roastery (or hybrids such as the Loring Smartroaster that are somewhere in between?) In my opinion yes.
I think fluid bed roasters (although I would not want to work on one again unless it had modified controls) have the benefit of delivering very consistent roasts with a short learning curve for the operator, minimal need for constant monitoring throughout each roast and minimal maintenance requirements. Risk of roasty or smoky flavors in the taste profile is nearly non-existent (assuming you do not grossly over-roast.)
Drum roasters have the benefit of allowing more granular control of roast profiles if in the hands of the right operator. I don't consider one type to be "better than the other and in many cases can deliver exactly the same result - but I think there is room for and benefits form both.
It's just a tool.
What matters is how you use it.
Absolutely right. That being said... what tool you select can make a difference.
