jkoll42 wrote:... I have nowhere near the palate/cupping ability to pull this off, so I am putting the idea out there to see if there is interest.
Suppose an expert, using a very tight cupping protocol, found a barely perceptible difference. Would you switch storage methods?
Go ahead and do it yourself. Make sure you cup blind, make sure there are several cups of each sort in the test, makes sure you try the coffee at various temperatures and smell the dry aroma, that's basically all there's to this. If the differences aren't fairly easy for you to spot in this side by side format, they are probably too small to make a difference your daily one cup at a time practice.
For testing two alternatives, I much prefer the 5 sample test to the triangle test whenever you can prep two samples of one kind, and three of the other. The chance is one in ten of guessing right, while it is only one in three in a triangle test. The test also compensates for same sample, cup to cup variation, while the triangle test does not. So one of these tests gives you as much info as two or three triangle tests. For brewed coffee, where prepping multiples samples is easy, this is the way to test preparation alternatives.
