# If the coffee tastes aggressive, you need more caramels and sugars, less flavors. Decrease the dose, and make the grind finer to keep the flow the same. This will increase the proportion of sugars, while keeping the acid bitter balance the same.
# If the coffee is too bright, with lemon, fruit, apple, wine and other acidic flavors, keep the dose the same, make the grind finer, to lower the flow rate. Make a slower flowing, more ristretto shot. This will reduce the acidity relative to the bitterness.
from
Espresso 101: How to Adjust Dose and Grind Setting by TasteAlso try a few days more rest
