farmroast wrote: .... but have wondered if any spices can/have been added to the grind before pulling?
Old world coffee blenders: cardamom and cinnamon. Masala Chai (or simply Chai) is basically milk+tea+spices. Turkish coffee is sometimes prepared with a coffee+hint of spice mix. Bedouin Arabic coffee uses spices too.
Adding either cardamom or cinnamon (but not both) to the PF has always intrigued me. There's the challenge of grinding them to espresso grind consistency then mixing them up correctly to maintain puck consistency to avoid channeling. That's such a big challenge that I haven't yet been able to do it correctly, the puck channels or I don't get much spice taste.
I'd probably go with mixing these spices with the milk then steam it (then filter the big spice chuncks out?). That would hopefully get you the spice hints you're looking for without the other troubles.
I'll go try some cardamom cappuccino with my dark roasted Kenya right away
