Bought some Dunn Bros Coffee... possible overroast but tastes good?
Postby bjax on Thu Apr 02, 2009 3:18 pm
and I had to adjust the setting on the major a whole number (read: thats a lot) from 3 to about 2.1. Anyhow the coffee poured evenly, but slow, my normal 2 ounce shot seemed heavier, not sure. Also grinding took over 12 seconds for a double. its much shorter when I roast.
Also it had a strong chocolate taste to it, the beans smelled musty and were very dark
what I remember most about the 1/2 pound I bought was that when I tamped it was literally like tamping a sponge, I couldnt believe how much it compressed.
Do you guys think the coffee was over roasted.... it didnt taste bad in a latte, really strong chocolate taste and all.
Orthotist/ATC
bjax
Postby another_jim on Thu Apr 02, 2009 4:44 pm
Of all the large coffee chains, I like Dunn brothers the most. That isn't saying a lot; but they mostly roast decent coffee.
another_jim
Postby bjax on Thu Apr 02, 2009 4:47 pm
I should say that today I tried a home roast and had to again adjust 1 whole number coarser. So obviously the coffee was more "moist" because the machine would clog at a setting of 2. I am wondering if my roast is being fried since it does not have nearly as much give when I tamp, meaning I can have a full portafilter and tamping will result in a little clearance. The dunn brothers just sank so much more when I tamped....
Orthotist/ATC
bjax
Postby bjax on Thu Apr 02, 2009 4:50 pm
Those who have mazzer majors, does this sound legit..... I mean 12-14 seconds for just a double. It appeared the coffee was so moist that it took longer to grind..... I have new burrs
Orthotist/ATC
bjax
Postby another_jim on Thu Apr 02, 2009 6:34 pm
You seem to suffering from grinder anxiety. Don't.
The range of grind settings required to do justice to different coffees is huge. If you went from a medium dark aged Sumatra to a medium light roasted Yrgacheffe (these are fairly close to the grinding extremes), you'd probably have to adjust 2 whole numbers coarser.
Set your grinder to whatever works for that coffee, drink the shot, be happy.
another_jim
Return to Coffees
