farmroast wrote:When I ship roasted coffee I'll heat seal a zipper valve bag to avoid any chance of spilling. Fill, seal and ship right off. For direct local where it will be used quickly I'll just use a good quality lined tin tie bag at about 1/3 the price. I don't think it's possible to slow the off gassing.
Hmmmm. Even if not, I think bagging immediately using the valved bags, as Ryan suggests, makes sense. (The best solution, of course, is substantial positive pressure using an inert gas, a la Illy, which should both reduce oxidation and maybe even slow degassing, but this is expensive packaging.) But yes, if you bag immediately into a tin tie bag this should be ok, as long as the coffee is bought and consumed immediately. The trick is that if the coffee is 10 days old already when you sell it, it may be getting stale by the time it's consumed if not already past its prime. (Esp. for espresso.) In the case where the coffee may need to be on the shelf for a week or more, seems to me like valved bags make sense. Of course, if folks have tested anything like this and found to the contrary, I'd be most curious to know!
