An Afternoon with the Slayer
Postby Abe Carmeli on Sun Feb 14, 2010 12:07 pm
On Friday afternoon, I had the good fortune of attending a coffee meet with Silvia Magalhães who is three times Brazilian National Barista Champion. The coffee jam was put together by John Moore of Dallis Coffee and it took place at RBC Coffee, New York, home of the Slayer espresso machine.
The place was nicely packed at 3:00 p.m. as Silvia was dialing in the grinder and extraction parameters. It took a good 20 minutes before she was happy with her shots, and as I received mine I was looking forward to that hazelnut bomb I remember from my last visit at RBC. It was a sweet shot with wonderful creamy body and indeed a strong hazelnut in milk chocolate backbone. The featured coffee was Brazil Nossa Senhora Aperacida Peaberry.
John asked if I would be interested in taking the Slayer for a spin. The man is clearly a mind reader.
Cora Lambert, the director of coffee and head barista at RBC was kind enough to give me a quick rundown of the machine's operation and off I went.
As I prepped my first shot I took a closer look at the three group Slayer from the Barista's point of view. It is very elegant and minimalistic in its design, and in the age of digital displays, it uses an analog pressure gauge next to each group. The handles operating the steam wands are clearly a homage to the Synesso. An additional practical touch is an angled reflective stainless steel plate that runs across the machine above the drip tray. It serves as a mirror giving the barista a view of each group from the bottom up. When pulling a shot, I could clearly see how the shot progresses, without bending. I could see the basket as it is saturated, a cue to move from preinfusion to full pressure.
driving the Slayer at RBC. In the picture Silvia Magalhães Brazil National Barista Champion & Abe Carmeli. Note the reflective stainless steel panel angled above the drip tray.
After a quick flush I locked in the portafilter and moved the paddle to 6 o'clock - the preinfusion position. The pressure gage barely moved for 6 seconds then started climbing up very slowly until it reached 5 bars. That looked like 20 seconds to me. I moved the paddle to full pressure position, and cut the shot at around 45 seconds. That would be a very slow pour for a double basket on a standard machine, but on the Slayer, most shots run between 40 and 50 seconds because of the very slow initial pressure ramp up. It tasted sweet and nutty but a bit grassy. Visually, the shot looked flawless, a clean centered cone, nice tiger stripping with no visible channeling.
A grassy note in espresso is usually cured by letting the coffee rest for a few more days before pulling a shot. Can pressure profiling get rid of a grassy note? This may be a fool's errand but it looked like a fun play to test drive the Slayer.
I pulled a few more shots, changing the pressure profile timing. This time 10 seconds before the end of the shot I moved the paddle back to the pre-infusion position. I watched the pressure crawl back down to~ 7 bars by the end of the shot. That very slow and gradual decline is reminiscent of a spring loaded lever machine, and cannot be done on a regular pump driven espresso machine. Flavor profile has changed, the shot was sweet, milder, and rounder, but there was that grass again. A few more tries with pressure timing and the shots went all the way from boringly sweet to, weird and undefined, but the grass note never fully disappeared.
All in all, this is a very enjoyable machine to work on. I suspect that the long preinfusion gives the machine a big forgiving factor in regards to channeling. The timing of the pressure stages gives the barista another tool to influence flavor, but consistently timing the pressure stages to achieve a desired result takes practice.
Many thanks to RBC's staff, John Moore and Silvia Magalhães for their hospitality, I had a great time.
Abe Carmeli
Abe Carmeli
Postby shadowfax on Sun Feb 14, 2010 7:56 pm
Abe Carmeli wrote:The man is clearly a mind reader.
Aren't mind readers great?
Sounds like an awesome time, thanks for posting this. I was wondering, above, if Silvia's shot had the grassy defect as well, or if you were using a different coffee from the Brazil peaberry coffee she used?
Nicholas Lundgaard
shadowfax
Postby Abe Carmeli on Sun Feb 14, 2010 8:12 pm
shadowfax wrote:I was wondering, above, if Silvia's shot had the grassy defect as well, or if you were using a different coffee from the Brazil peaberry coffee she used?
We used the same coffee and same grind setting, though maybe not exactly the same dosage. Silvia's shot also had slight grassiness, but much less than my shot.
Abe Carmeli
Abe Carmeli
Postby JmanEspresso on Sun Feb 14, 2010 9:23 pm
That looks like the makings of one very fun day, for sure. Thanks!
JmanEspresso
Postby another_jim on Sun Feb 14, 2010 9:32 pm
So, are you ready for the single grouper, if it ever comes?
another_jim
Postby Abe Carmeli on Sun Feb 14, 2010 10:05 pm
another_jim wrote:So, are you ready for the single grouper, if it ever comes?
It is on my wish list, right after a moon landing, performing at Carnegie Hall, and banning the word awesome from the English language. But only if they can miniaturize it to the size of the Mypressi TWIST.
It is really a fun machine to operate with a lot of potential. I'm looking forward to seeing La Marzocco's take on variable pressure later this year, and my feeling is that variable pressure will become standard within three years in the high end commercial machines. I'll be very surprised if we do not see one coming out of Synesso this year, though I base it on nothing but sheer speculation. But mark my words, it is coming.
Abe Carmeli
Abe Carmeli
Postby another_jim on Sun Feb 14, 2010 10:19 pm
Abe Carmeli wrote:It is on my wish list, right after ... banning the word awesome ...
rad-fab
another_jim
Postby HB on Mon Feb 15, 2010 10:21 am
Related article published last week about the same Slayer at RBC: What Kind of Coffee Do You Get for $18,000?
Postby Phaelon56 on Mon Feb 15, 2010 10:44 am
Abe Carmeli wrote:It is on my wish list, right after a moon landing, performing at Carnegie Hall, and banning the word awesome from the English language. But only if they can miniaturize it to the size of the Mypressi TWIST.
Awesome review - truly awesome :wink:
I agree about the likelihood of pressure profiling becoming a standard in high end commercial machines I think it's likely to become widely adopted only when it can be programmed in and repeated without manually adjusting the profile on the fly during the shot.
Phaelon56
Postby miKe mcKoffee on Mon Feb 15, 2010 1:12 pm
Phaelon56 wrote:I agree about the likelihood of pressure profiling becoming a standard in high end commercial machines I think it's likely to become widely adopted only when it can be programmed in and repeated without manually adjusting the profile on the fly during the shot.
Agree 100% programmable profiles need to be part of the equation. And not just line pressure preinfusion, but more variable. Including running a manual profile and then saving it of course. Especially when (not if) temperature profiling ability capabilities added to the mix... the possibilities become mind boggling endless!
Mike McGinness, Head Bean (Owner/Roast Master)
http://www.CompassCoffeeRoasting.com
miKe mcKoffee
Next
Return to Cafes and Get-togethers
