[SOLD] Rancilio Silvia V4 with PID White Numeric Digits Package (6 months of use)
Used espresso or coffee stuff you hope to sell or buy.
OceanPeakArch
#1: Post by OceanPeakArch »
Package Includes:
• Rancilio Silvia V4 with PID White Numeric Digits Installed (Retails $920.00)
• Rancilio Rocky Doserless Coffee Grinder (Retails $355.00)
• Rancilio Stainless Steel Base with Knockbox (Retails $115.00)
PRICE: $1,000 plus shipping via UPS.
*More photos upon request for all items.
Rancilio Silvia / Version 4
Sturdy stainless steel casing, brass components throughout and an upgraded commercial-grade steam wand make the Rancilio Silvia V4 one of the most popular machines on the market. Simple, reliable and powerful, the Silvia espresso machine produces excellent espresso and silky microfoam milk for your lattes and cappuccinos. Add even more consistency to your Rancilio Silvia with the addition of a PID controller. Installed by our own Seattle Coffee Gear tech department before the machine goes out, these units enable you to control the temperature variance on this machine by as little as one degree.
The PID that is currently installed will display white numeric digits
Features & Functionality of the Rancilio Silvia Espresso Machine
• Steaming/Hot Water: Featuring a commercial grade chrome-plated steam wand, the Rancilio Silvia quickly delivers plenty of steam for milk frothing and hot boiling water for your Americano or a cup of tea.
• Brew Group: Inspired by Rancilio's professional espresso machines, this chrome-plated brass group ensures even heat and water distribution, resulting in highly consistent espresso extraction.
• Pressure Release System: The commercial-grade pressure relief system utilizes a 3-way solenoid valve which makes for easier cleanup - either by reducing splatter from an inadvertently removed portafilter or by reducing post-brew drip, effecting a dried out coffee ground "puck."
• 67 oz Water Tank: The water reservoir is removable, making for easy regular care. You can fill it while operating or by taking it out and filling it from the sink.
• 15 BAR Heavy Duty Pump: A powerful water pump will effectively force water through your coffee grounds and extract full flavor.
• 12 oz Brass Boiler and Three Thermostats: Brass evenly distributes heat, so this boiler will get up to temperature quickly and easily maintain it through multiple repetitive uses. The thermostats monitor the espresso, steam and boiler heat to ensure excellent espresso extraction without worrying about overheating.
• Stainless Steel Construction: Brushed stainless steel case, rust resistant steel frame, stainless steel bolts, screws, heating element and only the finest fittings and tubing give this machine a sleek, industrial and functional design.
• Plug n Play: Requiring no special plumbing or electrical outlets, you can easily plug the Silvia right in and it's ready to operate.
• Portafilter and Filter Baskets: The Silvia comes with a commercial-grade, heavy-duty chrome plated brass portafilter and two stainless steel filter baskets (one for single shot, one for double shot) which measure 58mm in diameter.
• Drip/Cup Tray and Warmer: The stainless steel drip pan and cup tray are easy to remove and clean. Plus, a warming surface on the top of the machine gives you a space to warm your cup before you pour your espresso, keeping it at the right temperature - an essential element of fine espresso.
Rancilio Rocky Doserless Grinder
Rancilio. It's the most recognized name in commercial quality espresso machines and grinders. And now, the company has packaged all the professional features and functionality that they're famous for into its latest line of Rocky grinders. The Rocky Coffee Grinder is ideal for the coffee enthusiast looking for better control over grinding. Featuring 50mm burr grinding plates crafted of the finest tempered steel, the Rocky is designed to deliver 55 different types of quality grounds at the press of a button, all without imparting additional heat during the process. As for its functionality, it comes in a doser or doserless variety. With the doserless, you'll have more manual control over the amount of grounds you deliver to your chosen filter or carafe. And with a doser, you'll have the ability to tap out the right amount of grounds into the portafilter and then go straight to your espresso machine in mere seconds.
Features & Functionality of the Rancilio Rocky Coffee Grinder
Commercial Quality Grinding Burrs: The tempered steel grinding plates rotate at super slow speeds to prevent heat build-up, which can ruin your perfectly roasted beans. The hugely productive motor is also insulated to prevent overheating.
Excellent Home Hopper: The compact hopper is blue tinted for UV protection of your beans, but still easily see-through for monitoring of your bean level. The hopper holds over a half pound of beans, and lifts off for easy cleaning.
55 Ways to Grind: A twist of the grind dial on the Rocky gives you 55 levels of control over the output of the grinder. The ultra-fine threading allows you the versatility of going from espresso to drip to French press coffee brewing, and every other type between!
Quiet, Powerful and Safe: Rancilio designs for commercial use, and that means creating motors and grinders that emit as little noise as possible. The Rocky Grinder is no exception, and is one of the quietest available. Safety is just as important, with the balance of the grinding elements designed to prevent rocking and torque. Should the grinding mechanism jam or become overheated, a thermal protection devise shuts it down to prevent damage to the motor or the grinding mechanisms.
Ad approved by HB
