[SOLD] Quick Mill Vetrano 2B
- Compass Coffee
Lists new $2395. Purchased 12/7/2013 under warranty until 12/7/2015 through Chris Coffee
Asking WAS $1895 NOW $1745.00 cash, MO, cashiers check or $1797.35 credit card or PayPal ***PICK-UP Price***
Shipped machine will be insured for $2000, shipping charge additional at buyers expense. Examples to Southern California ~$116, to New York ~$150 UPS Ground.
Thought more about the value to me of the use I've got from it and decided to reduce the price!
In virtual mint condition. Been a great machine. Selling only because ordered home shot profiling machine upgrade today: Vesuvius
Will come with 2 QM Portafilters one double spout one single spout, 1 factory cut Bottomless Portafilter, QM double basket (never used), Synesso 14gr ridgeless basket (my go to), ridged and ridgeless triple baskets, (can't find the single basket! ), backflush blank, group brush (never used, have another one), a spare group gasket. I already replaced the group gasket a month or so ago and doesn't need replacing now. I can install the new one if wanted.
And of course bag with direct connect and drip tray plumbing. (I've run off tank and manual drip tray empty.) Water used filtered with Mavea Purity C300.
Steam tip perfect match for caps! Start shot, start steaming, stop steaming, stop shot.
Features:
High-quality stainless steel construction #304
E61 commercial group
Cup warmer
Hinged cover - No need to remove the cup warming tray to refill the water tank
PID controller for the group boiler (with 1.0 degree Celsius or Fahrenheit adjustment)
PID controller also controls the steam boiler temperature (and thus pressure)
Programmable offset differential
Dual pressure gauge
Power and heater lights and switches
No Burn, stainless steel steam and hot water arms
0.9 mm four hole steam tip
Large stainless drip tray
Dual insulated copper boilers
Rotary pump, placed vertically to prevent any motor issues
Easy access to the rotary, a tab on the right panel
Resettable hi-limit to protect the heating element
Gicar control board
Parker solenoid valves
Water reservoir with a low water sensor
Direct connect plumbing option (braided water line included)
Power switch that controls whether to obtain water from the tank or direct connect
Panels on the bottom base, access to the heaters and the boiler drains
15 or 20 amperage operational mode
3" clearance between the drip tray and the portafilter
Specifications:
Model Vetrano 2B
Manufacturer Quick Mill
Automation EE \ Semi-Automatic
PID Temperature Controller PID controller for the group boiler (with 1.0 degree Celsius or Fahrenheit adjustment). PID controller also controls the steam boiler temperature (and thus pressure)
Plumbing Reservoir (3 liter) for manual fill or Direct Plumb
rotary pump. Placed vertically (pump on the bottom, motor on top) to prevent any motor issues
Convenience / Functionality
Display Dual gauge. Power and heater lights.
Drain Tray Large pull-out stainless drip tray or remove plug and direct drain
Hot Water Spigot 1 No Burn stainless steel hot water spigot
Controls
Steam Arms 1 No Burn stainless steel steam arm with 0.9 mm four hole steam tip
Dimensions
Height 16.50 inches \ 41.9 centimeters
Width 12.00 inches \ 30.5 centimeters
Depth 18.00 inches \ 45.7 centimeters
Weight 70 pounds \ 31.8 kilograms
Electrical
Amps \ Volts 15 or 20 Amp \ 120 Volts
Watts 1100 Watt steam boiler \ 800 Watt group boiler
Features:
Cup warmer
Dual pressure gauge
Gicar control board
Specifications:
Model Vetrano 2B
Controls
Dimensions
Electrical
Mike McGinness
