Why Start With a Partial-Pour Bloom in an Aeropress? - Page 2
- drgary
This is why, of course, you'll grind to a particle size for your intended extraction timing and why you use a high quality burr grinder that won't create excessive fines.MWJB wrote:Doesn't this work just as much in our favour? The fines sinking quickly & settling together hopefully in such concentration as to stall their extraction, the boulders still floating/in low concentration liquor, thus able to carry on extracting until knocked down, or sinking of their own accord later in the brew?
LMWDP#308
LMWDP#308
Indeed, but all burr grinders typically produce a range of particle sizes at any setting, all make fines & boulders (without sieving), just in differing proportions.
- drgary
Yes, there is imperfection all around us. Fines aren't a problem if you're using a quality grinder.
LMWDP#308
LMWDP#308
- TomC
Not to be argumentative, but fines are a problem in any grinder. But even more specifically burr grinders versus large flats.
- endlesscycles
You may be right here.MWJB wrote:Doesn't this work just as much in our favour? The fines sinking quickly & settling together hopefully in such concentration as to stall their extraction, the boulders still floating/in low concentration liquor, thus able to carry on extracting until knocked down, or sinking of their own accord later in the brew?
-Marshall Hance
Asheville, NC
Asheville, NC
- endlesscycles
My EK-43 has a fines problem. So there.drgary wrote:Yes, there is imperfection all around us. Fines aren't a problem if you're using a quality grinder.
-Marshall Hance
Asheville, NC
Asheville, NC
I was just making a cup of coffee in my Aeropress this morning when I asked myself the same question as OP, Googled and found this thread. I thought that blooming had to do with releasing trapped CO²? So I wondered why that would be necessary, since the grounds are immersed for the extraction period, rather than having water forced through for a brief time by pressure or gravity... In my mind, if I'm using inverted method, the CO² has the same amount of time to escape if I bloom or if I don't bloom. Am I off base here?
After hundreds and hundreds of Aeropress coffee, I can say this: I've never made a cup without blooming that I felt was awful because I didn't bloom. I've also never felt like the cups without blooming were much better or worse. Since Aeropress is closer to immersion brewing than pour over, I'd say the choice is down to preference.
- yakster
Probably also the act of stirring alleviates the need for a bloom.
-Chris
LMWDP # 272
LMWDP # 272
- cannonfodder
I use a fine grind, just a bit above an espresso grind. Pour in my hot water, give it a 15 second or so stir with a coffee straw, top off the water and press for about 30 seconds. Works good for me. A good heavy stir breaks up the bloom and gets all the coffee in suspension.
