Sherman wrote:For a while now, I've been using input measurements (brew water volume & grounds weight) rather than output for my vacpot, and have found it to be quite consistent. FWIW, I typically use 55g/1200ml with a total brew time (including soak & drawdown) of about 4 minutes. For lighter roasts at City to City+, which is what I've been roasting and drinking lately, this produces a wonderfully full cup.
55g/1200ml is a coffee:water ratio of 1:22. This is far lower than the generally accepted standard of 1:17.* I suspect I would find your vac pot brew weak and overextracted.
4 minutes is on the long side for typical vac pot brewing. If you have not already done so, try more coffee, a finer grind, and a shorter extraction time.
It goes without saying that you should follow your own taste buds. If you have already experimented with standard brewing parameters, and really do prefer it "your" way, please ignore this post.
* Scott Rao in
Everything But Espresso suggests "a brew ratio of 1:17... should be nearly optimal for most coffees and palates." (p.17) The SCAA recommends 60g/1000ml.
