by jlhsupport on Mon Jan 10, 2011 5:53 pm
I do care in fact, and unless you got a mysterious bad batch of filters, those are probably fine.
What I would recommend is that you give a rigorous scrubbing to your kettle followed by a descale to get any potential manufacturing residue off. Personally, I have little experience with the Hario brand, though their reputation is sound with or without my endorsement. I have experienced with some household equipment that manufacturers recommend a descale before use, so that's the only reason I would say so in this case.
Regarding your coffee, how are you storing it, and what is the roasting date?
Regarding your water, I am having trouble finding a water quality report for LA and surrounding areas, but from what I can tell based on the USGS Water Hardness MAP, the water is very hard over there. A filter does not remove hardness, usually just chlorine and some other organic materials. What kind of filter are you using, and when did you last change it? They do get funky if left in use too long. Also, loose carbon filters actually form channels (much like poorly distributed ground espresso) and can cause the water to flow through already saturated areas of the filter, rendering them quite ineffective.
Joshua Stack
JL Hufford
