Hario drip cones
Postby Teus on Mon Mar 28, 2011 5:10 pm
When I'm traveling I like to make coffee for everybody, so I would like to buy a drip cone that can make a large quantity of coffee. I never used them before however. Hario lists 6cup drip cones on their site: http://www.harioglass.com/coffee/dripper.html
However, I have trouble finding the 6cup on webshops.
This PDF says you can make a whopping 24oz/780ml from seemingly a 4cup cone:
http://www.terroircoffee.com/Hariodripp...ctions.pdf
can somebody clear this out, or should I just go and buy a 6cup Melitta cone 8)
Teus
Postby yakster on Mon Mar 28, 2011 9:54 pm
The North American channel for selling Hario, Roustabout Products shows the Clear Plastic 6 Cup VD-03T available, but that may be of little help to you in Belgium.
Maybe Hario figures that us Norte Americanos enjoy a supersized cup while the rest of the world is more moderate in their coffee consumption. I donno, I recently scaled back from pouring myself 350 ml to only 200 ml of coffee for my morning commute and once I adjusted I'm fine with it.
For family gatherings, I like the Chemex + Coava Coffee Kone for 1 liter batches. I tried a 1.5 liter batch but bloomed over the side. Stainless Steel french presses also work well for large batches and may travel better then a glass Chemex, but you should be able to use a Kone in a V60. Both these methods give you a lot of body, oil, and some sediment.
Sorry I'm not more help, but I've yet to pick up a Hario V60 cone and lately have been using the Clever Coffee Dripper with 450 ml of water and 28 grams coffee to brew 400 ml batches. Good luck.
yakster
Postby gt on Tue Mar 29, 2011 10:32 am
Teus wrote:This PDF says you can make a whopping 24oz/780ml from seemingly a 4cup cone:
I tried 48gm coffee/780gm water this morning in my V60 02 cone and server. There's no problem with the cone holding 48gm of coffee (actually it's a nice amount) but the server got clear full and would overflow a little if I didn't remove it. Every morning I do 42/700 and it's OK but that's about it for the server.
I do 24g/400g using the 01 cone and that works good for a single cup.
Edit: I watched closer this morning when I did my normal 42/700 with the 02 cone and server and the server level was about 1/2 inch from full to the top.
gt
Return to Coffee Brewing
