Grind setting for Chemex using Baratza Vario-W?
Hi
Is anyone using a Vario to grind for Chemex? What settings are you using? I don't know if it matters, but my Vario has the metal burrs.
Thanks
Jay
Thanks
Jay
Comparing settings is pretty much useless because calibration will vary from grinder to grinder.
That being said this morning I ground 45g on O-8 for a 700g brew in 4:15 in an 8-cup.
Normally I'm somewhere around O-7, 30g, 500g, 4:00, but I wanted a larger batch to take some to work. Then I left my thermos sitting by the front door (It was Intelli's current Costa Rica, really good)
O-7 is also what I normally use for v60 as well, 28g in 415g out.
