Grind setting adjustment for one/two serving Hario V60?
stelli
#1: Post by stelli »
So just wondering, do you adjust the grind size from small, single serve Hario V60 to the larger, two serving Hario V60?
Stevebcoffee
#2: Post by Stevebcoffee »
Personally I do. For 1 cup I use 17g coffee, 275ml water with a grind setting on the Hausgrind of 1 + 5.
For 2 cup I use 34g coffee, 550ml water, with a setting of 1+11 on the Hausgrind.
I use a 30s bloom in both cases and the brew time in both is c 2m45s
I know some people prefer to change the pour technique to speed up the larger brew and keep grind size the same but I find that by changing the grind and pouring the same the taste profile is the same for both and the results are much more consistent and repeatable.
