French Press - it is great for Tam's Brewing Method
Postby pstam on Sat Aug 13, 2011 1:45 am
I used to say a lot of times that the French Press is the greatest tool for filter coffee brewing because it is fully controlled by hand. How do you think of it?
A couple of years ago, I started a new way to manage it and found that it was really great if one can use it in my way.
The Tam's way of French Press is this,
1. Clean the French Press, and pour some hot water to make it hot and dry it again
2. Put some coffee ground in it, say 10 grams for a cup, and then pour hot water in it; remember to leave the filter out of the cup, not to cover it in the cup
3. Shake the cup so that the coffee ground is mixed with hot water, not to be kept closely and tightly at the top of water, from time to time; remember now that you can see the crema-like at the top of the water
4. When you see that most coffee ground fall into the bottom of the cup, and the crema-like disappeared, it means that the extraction has been finished well and you can put the filter in the cup and press it to the bottom; since the coffee ground has been fall to the bottom of the cup, you do not expect any force as pressing the filter.
Explanation:
Those coffee ground fall down to the bottom of the cup due to the fact that they had been fully dipped in the water and the effective compounds had been well extracted into the water, so they fall down to the bottom and shows that the extraction should be finished.
Its benefits:
Whatever size the coffee ground, at least in a reasonable range, one do not have to worry about the time. Just wait for the coffee ground falling down to the bottom of cup, then press the filter and finish the extraction. The time of extraction can be automatically fit the grinding size of the coffee ground to the best.
For my poor English, a friend has his own description, as below:
1. Preheat the pot.
2. put about XX grams of ground coffee in the pot
3. evenly and steadily pour about XXX ml XX degrees hot water on the coffee
4. put on the lid to keep the heat in the pot
5. now smaller particles start to sink to the bottom as they absorb the water, but still a large part of the particles float on the surface, the bubbles around the them prevent the extraction process
6. now gently and slowly swirl the pot, or use a wooden spoon in case the pot is full and will easily spill
7. Do not time the extraction period! No matter it is 4min, 5min, or 6min, you won't know when the over-extraction starts until you taste your coffee--but it is already too late! And do you know how many cups of over-extraction or under-extraction coffee you have to make until you find the steeping time that suits? It's such a waste of time and coffee beans!
8. The perfect moment for ending the steeping is when most of the particles start to fall from the surface.
9. So, when you swirl your pot, watch sideways and when you find a large part of coffee particles start to fall you can start push the plunge down. A few larger particles will remain on the surface and smaller particles have already been sitting at the bottom for a little longer than we want. But that's what the press pot flavor is from. As long as most of the particles start to fall, the coffee is generally fully not overly extracted.
10. The plunging process is surprisingly effortless, since there won't be much resistence left on the surface!
Some of the steps in this method originate from the Old West cowboy coffee brewing method.
pstam
Postby the_trystero on Sat Aug 13, 2011 2:28 am
Thanks for that. It's kind of a cross between cupping and the standard use of a French press.
By the way, how's the coffee scene in Beijing now? I was in China in 2006 and only found one decent cup of coffee in Pingyao, a siphon (my first siphon, actually) heated over a sterno burner.
"A screaming comes across the sky..." - Thomas Pynchon
the_trystero
Postby pstam on Sat Aug 13, 2011 2:49 am
If you could have a chance to visit Kaffa Cafe, you might be surprised for a decent shot of espresso.
The coffee market in China is rapidly expanded but the brewing skill is still a big problem.
My way of French Press is simple, but very effective for brewing great drip coffee due to the automatic fit of grinding size and extraction time. More than any others, I suppose.
For the two descriptions, which one do you think is easy to understand?
pstam
Postby the_trystero on Sat Aug 13, 2011 4:42 am
Actually, they're both good. The second one is better because of the additional details.
I'd love to visit again, but unfortunately it won't be any time soon.
the_trystero
Postby cannonfodder on Sun Aug 14, 2011 11:32 pm
If during the press, the plunger starts to bind, dont force it. Give it a little tug up, about 1/6 1/8 of an inch. That will dislodge the grinds plugging the screen and you can continue pressing the plunger. I dont push it all the way to the bottom. I usually stop about a half inch above the coffee then decant.
cannonfodder
Postby Randy G. on Mon Aug 15, 2011 8:13 am
The French Press has a lot to offer, and still is a favorite method of brewing for a lot of people, it offers full-immersion of the coffee in a low-tech device. It creates a full-bodied beverage without over-heating the water or filtering out important taste elements with a paper filter. But the particulate matter that also remains in the coffee adds a harshness and bitterness. Anyone who has made the mistake of taking that last sip from the cup can attest to that.
The Espro Press solved all that. The filter system works so well that once plunged, the grounds are separated from the beverage and extraction is effectively stopped. It's not inexpensive, but the vacuum insulated stainless steel vessel won't break like glass press pots. In my opinion, in terms of the quality of the beverage produced, it makes the "traditional" French press obsolete.
The current one-cup model should be joined by a three cup late this year or early next.
Espresso! My Espresso!
Randy G.
Return to Coffee Brewing
