Diguo stainless steel vacpot filter - Page 3
- Peppersass
- Supporter ❤
To answer my own question, #2 is out -- really can't clean the Diguo filter thoroughly with it in the funnel. As for #3, a little vegetable oil makes it a little easier to get the filter out, but not much. So it's probably #1 for me.
As for brewing, I really like this filter! The grind, steep, stir and draw down parameters are essentially the same as paper filters. Maybe 3-5 seconds less steep time, but otherwise the same. Results in the cup are excellent. I get the body and oils that the glass rod lets through, but none of the grit and chew. While I do like the glass rod better than the paper filter, I have to grind finer, have to wait longer for a strong vacuum to form and need a much longer steep time. I get a better cup faster with the Diguo filter.
I'm having a hard time seeing why I'd use the glass rod, and I can't see any reason to use a cloth filter.
However, every now and then I want a super-clean cup so I can taste subtle fruit and floral flavors. That's where the paper filter shines.
I have a Yama 8 cup (40 oz) and an Adcraft stainless. I use my Silex "lox-in" glass rod with both. There is a bit of silt, but no "grit."
Evan, did I miss what siZe vac you had. I can measure the opening on my Yama. I ASSUME there's a bit more space surrounding the hole/stem than the 3 cup model?
Thanks for bringing this to us!
Edit...looks like about 58-60 mm from slope to slope where the Diguo would fit.
- JohnB.
Mine came but aside from checking the fit in my 2 Hario Nouveau vac pots I haven't tried it out yet. It fits fine in both the 3C & 5C pots, just like the cloth filter holders that I've always used.
LMWDP 267
- Peppersass
- Supporter ❤
It doesn't wedge tight in the 3C? If so, the 3C Hario Nouveau funnel must be slightly larger in diameter than the Yama.
- JohnB.
The Nouveau has a wider area at the bottom then your Yama 3C. http://www.avenue18.ca/TEAPOT/Hario/cof ... veau_3.htm
The Diguo filter drops in & out easily.
LMWDP 267
- Peppersass
- Supporter ❤
Sadly, it looks like the Nouveau stand won't work with my halogen heater. Just curious -- where can one buy the Nouveau?
- JohnB.
Just click on that link & place an order. I believe that Raymond at Avenue 18 may be the only North American source but you could check around. I bought all my Vac pot gear from him including an NOS Nouveau 5C & all the spare globes & parts I'll ever need.
LMWDP 267
- Peppersass
- Supporter ❤
Thanks. But alas, it looks like the base won't work with my halogen heater. Is it metal or plastic? Is there a hole in the middle? If metal and there's a hole, I could cut a slot in the base to slide it over the heater.
Or, will the globes work with the clamp in a standard Hario or Yama 3-cup stand?
- TomC
I can't imagine why it wouldn't work in my halogen heater. It's silicone, it should be pretty robust. I should break out my 3 and 5 cup and try it out to be sure.
- JohnB.
Sent you a PM.Peppersass wrote:Thanks. But alas, it looks like the base won't work with my halogen heater. Is it metal or plastic?
LMWDP 267
