by pjanson on Sat Apr 09, 2011 1:51 am
I walked a similar road getting my espresso machine. Started out figuring I'd get the silvia (about a billion home espresso fanatics cant be [and aren't] wrong!) but then realized that once I added the pid, i was almost spending as much as an alexia, which I think has a lot more to offer in the stability/repeatability range. (Un?)fortunately, for a little bit more than the alexia, you can make another significant jump up into the range of e61 hx machines with larger boilers. I ended up getting a used quickmill vetrano, for basically the same price as the alexia.
Caveat: I'd only recommend getting a used machine if you are confident that you can troubleshoot and fix it yourself. That said, most machines (pid excluded) are mostly mechanical/non-computerized circuitry. If you are mechanically adept, you can figure them out. Plus there is an amazing support community @ this place called home-barista.com (thank you all so much.)
So: I am so incredibly happy with my vetrano. An added benefit of hx machines over the alexia is the hx cooling flush guide on this site. It really clearly spells out how to rock consistent temperatures.
If you like lattes now, you are going to like them even more with great espresso. Don't expect to give them up (unless your budget really necessitates it,) just because your shots are phenomenal on their own. Milk brings out different flavors in espresso, and I have brewed some coffees that I thought were actually more complex and delicious with a little milk in them.
The combination of a rotary pump and a brew pressure gauge (often listed in features as a dual manometer,) gives you improved control on brew pressure, the adjustment of which can help dial shots in to perfection.
As far as grinders go, having worked coffee, I know that Mazzers are phenomenal grinders, and that they are built like tanks. If the motor works, anything else is easy to repair. They last for ever so I think getting a used one (so long as its in working order of course,) would be a safe bet that would ensure that your grinder will never be a limiting factor. If you can find one in your price range, Id recommend the heck out of it.
