http://sfbay.craigslist.org/sfc/app/1950227636.html
CarolinaEspresso wrote:BeastinBarista is absolutely right.
You don't want your espresso ground in a coffee grinder. They make espresso grinders that grind and drop the espresso right into your portafilter.
Espresso grinders are meant to be kept at the same fineness for consistent shot quality.
You should never want to grind your espresso in bulk anyways. You want to use the grinds within 24 hours of grinding them for optimal crema and sweetness.
And wtf is that thing? How big is that hopper?! Why would you ever need to grind that much coffee at once?? Even BUNN's(the leader in grinders and coffee brewers) largest grinder only grinds 3 lbs at a time.
