jugi63 wrote:Hi there Sir A,
Funny - we both live here in the north in neighbouring countries but discuss coffee issues via a coffee forum in the States.
Yepp, I also visit a swedish forum, riktigtkaffe.se, but home-barista is a lot larger, and so contains a lot more knowledge!
jugi63 wrote:Anyway, thanks for the response! Ok, so if I'm to understand correctly: if we have a couple friends over, the Jr DB will be sufficient.
Absolutely. I think the bigger issue will be having to grind, tamp and extract for many people in a row
jugi63 wrote:Then the boiler issue. So so far there hasn't been any responce or enlightning from the manufactors side about this? And you haven't added a PID which would solve the problem?
No, not from what I have seen. I will sometime in the near future add a PID, but I get by for now.
jugi63 wrote:You say that you are now keeping both boilers on at all times. So does this mean that the brew pressure/temp is set to the about 91 degrees with both boilers on, but if the steam boiler was to be turned off the brew temp would rise?
Exactly! And with the brew temp set to keep at 91-92 with both boilers on, turning the steam boiler of will bring the brew boiler close to boiling point. Not sure if this would be something to worry about.
jugi63 wrote:And still, have you or anyone else had a chance to try the Vibiemme Jr HX version?
Thanks!
- Jukka
I have not. Haven't tried any HX actually.
Cheers!
