innermusic wrote:Thanks Louis. Good thread. Still happy with your choice?
Perfectly. Having a 53mm group could seem revolutionary in a 58mm standardized world but this would be my only
issue with the Vivaldi. The outdated LED control panel crossed with button combinations mnemonic tricks should be addressed by La Spaziale, but with the quick reference card hung inside a cabinet door, every setting is easily configured (temp, volumetric dosing, pre-infusion, group temperature offset, etc.).
The main serious issue discussed on s1cafe.com forums seems to be pump leakage, which as nothing to do with the Vivaldi itself, as the motor and pump used by La Spaziale are the same found in other brands.
When I made my comparison, the Vibiemme DD wasn't out yet. I see it as a good challenger to the Vivaldi, if you don't mind having a semi-auto instead of a full-auto. Maybe Vibiemme will eventually offer a full-auto version...
I do use volumetric dosing almost every morning for cappuccinos, once the grind/dose is correctly set for one particular coffee (requiring only a slight adjustment from day to day, as the coffee ages).
Quality control/fit on the Duetto seems to be a frequently discussed topic lately. This post from Oton (owner of both a Vivaldi and Duetto) on S1Cafe.com forums speaks for itself:
http://s1cafe.com/viewtopic.php?p=19228#p19228. This adds to the design issues I identified in my (way too) long DB feature comparison: rotary pump on top of motor (and pumps do tend to leak over time), PID in what seem to be the hottest part of the machine (almost on top of the steam boiler), SSRs using the stainless steel front panel as a heatsink (close to the hot E61 mass and stainless also being a poor heat conductor).
If someone doesn't mind the lack of full stainless panels and the 53mm group, I can't see why the Vivaldi would not make their shortlist, or even finish on top of their list.
