by boar_d_laze on Fri Sep 16, 2011 9:04 pm
If you're still thinking about the La Cimbali Casa, this may help update Dan's old review of the DT/1 (non Casa) on the Review page. It's not meant as a sales pitch or a direct comparison to the VBMDD. They're different in several ways and one will definitely be a better fit than the other.
The old DT/1 and the new DT/1 Casa are different machines. The old one does not have pre-infusion, the home-friendly steam tip, or the dual gauges. Most, if not all, of Dan's caveats in the HB review regarding the high level of barista skills needed to make the DT1 sing don't apply to the Casa.
Looking at the HB review's conclusions, I'd give the Casa an extra point for "Exceptional Espresso," and "Morning After," and half a point for "Cappuccino Lover's [sic]."
Yes, pre-infusion takes a huge onus off the barista when it comes to prepping the baskets. Now a good prep works great; and that's quite an improvement.
Don't overlook how much easier the new tip makes things for (controlled) steaming normal quantities of milk either. In addition, Chris ships the Casa with the boiler pressure set higher than Dan had his. I.e., 1.2 vs 0.9. Even with the new "residential" tip, the Casa steams faster set this way than the old DT/1 did with a swapped out tip and arm at the lower pressure setting.
To get the most out of the Casa you still have to learn how to use cooling flushes to get your desired temperature range (something I mostly do by ear). If you're not familiar with HXs it will take you a few weeks to a couple of months (at most) to develop very fine control; but if you're familiar with temp via flushing it won't take long at all. The previous DT/1 was as definite and unamibigous as other great HXs like the Elektra Sixties and Nuova Simonelli Aurelia and Apia. And the new DT/1 Casa is just as good.
Thank God it's plumbed in. With the boiler pressure up, the base temperature is high and you'll end up flushing a lot of water to get to proper brew temperatures. But so what? The water goes down the drain without any effort on your part, and it's still cheap. If you've only used an HX with a reservoir, plumbed-in is a new and wonderful experience.
My experience with DBPIDs is limited, but I find a good HX is actually quicker and more efficient for on-the-fly temp adjustments. At the risk of redundancy, the Casa is very good at this. Like most really good machines -- including the VBMDD -- the Casa is quite revealing. As a matter of daily use, I usually have grind and temp well dialed in for the second shot.
Overall, it's a very friendly and forgiving machine, as simple as anything I've ever used. I don't think you get much simpler operation from a PID controlled double boiler, and you're certainly not going to get anywhere near the build quality and reliability from a DBPID anywhere near the Casa's price. This is another area is where the Casa really stands out. I can't overstate how pleasant the La Cimbali is to the touch, how well made it is, and how good it looks under the hood.
If you want the reassurance of DBPIDs' digitally precise temps you can't find them in a Junior. If you want Rolls-Royce "like buttah" smoothness and hugely over-built engineering, you won't find them anywhere else. When I was buying, my final choice came down to an LM GS3 or an LC Casa. The Casa was the right one for me.
BDL
