Eiron wrote:I understand exactly what you're saying. But people want different things for different reasons. What may seem impractical to you or me, may seem like a necessity to someone else. (I choose to drive a base model car with a manual transmission because I enjoy interacting with all the mechanical bits. My wife absolutely refuses to drive anything other than a fully loaded car with an automatic transmission.)
I guess that's why there's so much equipment out there to choose between ....
Now I'm gonna put on my engineer hat and give you a reason for why I think what I think about the Versalab press.
First, in engineering there's a concept that you should try to keep everything as simple and efficient as possible, that way your product has a smaller chance of not breaking down, and it keeps the cost of it down. In layman terms this is known as KISS (Keep It Simple Stupid).
Now comparing the Macap and the Versalab.
The Macap is nothing more than a dynamometric tamper fitted to a standard mechanical press. This allows; a) completely repetitive tamping pressures b) a comfortable working position c) less strain on the operator due to the mechanical leverage of the press. It also has the added benefits of being completely self sufficient, doesn't need to be "installed", just slam it on the counter and off you go. It also only relies on 19-century mechanics and is therefore quite available to survive the apocalypse, as long as you clean it and maybe oil it a bit every other year. Now, if the tamper is well designed, you can probably adjust the pressure of the tamper as well, but that's marginally useful at best.
The Versalab on the other hand;
a) is an intricate mechanical device, therefore much harder to service and maintain and prone to more breakages (this isn't an opinion, it's an engineering fact) b) it needs an external energy source other than the barista, which means it wastes energy and therefore money c) the different energy sources available all have their different faults. Water needs quite the installation, and needs to be done properly to avoid leaks that can damage the surroundings. It's also quite wasteful both money- and environment-wise, since the water isn't used for anything than the mechanical energy in the water pressure, the rest goes straight into the drain. Shop air isn't available in any café, and the compressors are noisy and require a lot of energy. Bottled CO2 costs a fortune, and you shouldn't release it into an enclosed space any old way (ever heard of carbon dioxide poisoning?). If someone pointed out that fact to the authorities then they would probably shut down your shop just because of unsafe working conditions. d) it doesn't seem to have any safety shut-offs. What do you think happens to your hand if it gets stuck between a portafilter and a piston trying to pack the coffee at 30 pounds? Might not be life threatening, but it would still give some very nice crush injuries, and you would probably get your business license suspended for unsafe working conditions. e) is it certified in all the ways needed for food preparation equipment?
When you then factor in all this you see that they have overdone themselves by overengineering something that was a relatively simple problem to solve initially. When you then factor in the problems people have had with the M3 Grinder and the aftersales support on it, then you really have to think about how wise a choice it is to buy an even newer and untested product from them.
Still, I'm not saying Versalab is a bad company, I'm just saying that the press is unnecessary complicated for the task at hand, and that they could work a bit more on support and "polishing" of their products. They seem to have adopted a bit of "we-are-geniuses-and-the-world-doesn't-understand-that-so-they-can-all-just-bugger-off"-attitude.
