vettman wrote:Have you tried backflushing the New Baby? I know Gaggia does not recommend it, but I've read varying reasons as to why. I was just going to use some de-calcify solution from time-to-time, but I wasn't considering grounds in the 3-way.
Yeah, I do a clean water backflush about once a week or so. I've never used chemicals to do it. When you descale the machine (recommended every 3 months, depending on usage and your local water) it seems to clean it really well.
vettman wrote:Also, I'm sure you probably know this, but there is some overlap built into the Vario. When I changed from the finest macro setting to one below the finest, I moved my micro setting to the top (finest) and found the grind was actually finer. I did not get back to where I was until I was down about five (5) clicks on the micro. I called Baratza to confirm this, and the support person I spoke with said that was exactly right.
Yeah, there is a bit of an overlap there, which is better than a gap, I suppose.
