by brokemusician77 on Wed Feb 10, 2010 6:33 pm
Congratulations! That's a great find. I got my Vario a little cheaper too. It was the display model.
I have the exact same setup as you, so I'm sure we'll be able to compare notes a lot.
Depending on the coffee I'm using, my grinder is usually set all the way up on the Macro slider, and about half way up on the micro slider. Timer is set to 12 sec, for this particular blend. Different coffees will require different grind settings and doses.
I'm sure you'll enjoy your new setup, and hopefully it'll give you lots of room to grow!
Cheers!
"There's a fine line between hobby and mental illness." - Anon.
LMWDP #326
