JmanEspresso wrote:And the Linea doesnt "need" a pump to work? This is interesting. How does it work then? I assume you mean, it will fill and feed water, but only at line pressure. . .
That's what I mean. It will be fully operational without the pump (hooked straight to the water line), but you will only get line pressure. This is more than adequate for testing out every aspect of the machine except the full-pressure 9 bar test. You can brew espresso if you want (again at line pressure), and it will be interesting--very drinkable, virtually no body. The main purpose is definitely damage assessment.
Anyway, the machine ought to be fine if the seller is telling the truth, the whole truth, and nothing but. If you trust his word with your money, then you're safe. If you have doubts, you may want to press for a test.
