innermusic wrote:I'm also getting good results out of my MXK, for around the same price as SJ.
boar_d_laze wrote:... I don't know the Silvano at all, but it might not have as much "resolving power" as the OP's next machine.
BDL
EricBNC wrote:What is "resolving power"?
boar_d_laze wrote:What I meant by "resolving power" was the machine's ability to reveal the nuances of the coffee (or at least stay out of the grinder's and barista's way). To my mind, that ability is key to defining the difference between excellent, very good, good, and adequate machines.
BDL
EricBNC wrote:If the machine can hold a pre-determined temperature (in the portafilter) through the time it takes to pull a shot while applying proper pressure as well - would this machine "stay out of the way" with enough "resolving power"?
HB wrote:(the thread Pressure profiles, preinfusion and the forgiveness factor was my most public mea culpa on this point). Such metrics are the favorite fodder of this vs. that discussions, but that's because they're easily measured. Considerations like "how evenly does the dispersion system diffuse water over the puck?" or "is its preinfusion design effective at mitigating channeling?" are hard to measure, but I argue more important than whether the brew temperature is held within 1.0°F of the setpoint. Were this not true, few would see the need to upgrade beyond a PID'd single boiler like the Rancilio Silvia, and yet there's ample evidence that many choose to do just that (e.g., How long before you upgraded from a Rancilio Silvia-class espresso machine? suggests more than half do in less than 2 years).
HB wrote:Not to barge into this discussion, but in my experience, attempts to correlate various metrics like temperature stability and proper brew pressure to actual in-cup performance are folly
boar_d_laze wrote:Do you plan to single dose?
Do you change coffees frequently?
Why doserless?
Rocky/Silvia is one of the few combos where upgrading the machine first might make sense.
BDL
