by sportflyer on Thu Dec 16, 2010 8:14 pm
I have been using the Carezza with a Quickmill Stepless grinder for about 2 + years . I make mostly milk/soy based drinks , 1 or 2 per day only. To get better frothing capability from the Carezza, I removed the outer frothing attachment and use only the inner pointed plastic tip ( single hole) . This seems to have improved the steaming capability quite a bit . To improve the reach, I have brazed on an additional 2 1/2 inch brass pipe extension on the main down stem before the plastic tip rather then replacing the whole steam pipe with a Rancilio Silvia pipe. The biggest problem I face is the machine running out of steam power during the texturing phase. I would like to upgrade to a machine with better steaming power. I have read reviews of the Rancilio Silvia , Bezzera BZ02 and the NS Oscar but cant decide which . I am also not adverse to buying used equipment from a reliable source . Budget is around $900
Recommendation please . Thanks
