by jools on Sat Oct 09, 2010 3:25 am
Hi everyone!
My name's Julian and I'm a coffeeholic! (just a quick, first-post intro!)
I've been spending some time reading the HB forums and on coffeesnobs here in oz, but there seem to be more lever-aficionado's here so I'm hoping you can help with some advice...
My current setup is an Ascaso Dream single boiler with an iberital challenge grinder. I tend to drink double-shot lattes and an occasional espresso. The espresso is only occasional because the shots are rarely inspiring enough to drink as an espresso, but generally they work ok as a strong latte.
My usage is fairly low - I don't have time in the morning to make a coffee at home so I use an aeropress and kyocera grinder at work to make short or long blacks. The dream and iberital are therefore used mostly on the weekends and mostly just for me. Occasionally when friends are over I'll need to make 4 - 6 milk-based drinks, but this doesn't happen too often.
I'm getting a bit frustrated with the current equipment as it is very inconsistent. It's difficult to dial-in for a new bean, which is probably common on other equipment too, but it is also inconsistent from shot to shot - the same bean, grind, dose and tamp may produce a decent result or something burnt and bitter.
I'm also hoping that an upgrade will improve the flavour as, from what I've read on the forums here, people upgrading to an e61 from a silvia or similar are getting much better flavoured result.
Initially I was thinking of upgrading the grinder first however I'm thinking that the machine is the weak link in the current setup and the grinder is doing a reasonable and consistent job. It will also be upgraded at some stage but I'm thinking that a super jolly would hindered by the ascaso dream, but a better machine with the iberital challenge would be a bigger improvement and I can go to a super jolly or similar as the next step.
So then in looking at new machines I've been reading a lot about the PV Lusso 2 group and it sounds like a great thing, but I'm a little concerned about it's ability to produce a good, strong latte compared to an e61 machine. I'm sure my usage will change over time and I will be drinking more espressos with a better machine, but I do like the flavour of a strong latte, it lasts a bit longer than a one-gulp espresso and when friends are over they all drink milk-based coffees.
In Australia, at a similar price point to the PV Lusso (around $AU1450), the choices are the high-end e61 single boilers like the Vibiemme Domobar Piccolo or Isomac Zaffiro, or an entry level HX machine like the Nuova Simonelli Oscar or Expobar Office Semi Auto. I've had a chat with a shop in Sydney that sells various machines (but not the Lusso) and they suggested the Vibiemme Piccolo which they would temperature calibrate with a Scace. They suggested that the low-end HX machines are not temperature stable and if my budget didn't stretch to a decent HX ($2500 plus) then I would get a better and more consistent result from the calibrated Piccolo.
This sounds like very reasonable advice, but the shop is not familiar with the PV Lusso so they can't make any comparisons.
I understand that the Piccolo won't steam and brew at the same time like the Lusso. I've also read that the Isomac Zaffiro takes over 3 mins to switch from brew to steam - does the Piccolo takes as long? I'm assuming that with similar boiler size and heating element that it would be a similar time. It's not that big a deal though as I'm used to this from the current setup.
The Lusso has an obvious advantage of brewing and steaming at the same time, but is it capable of producing shots strong and flavour-ful enough to work as a strong latte? I've seen a post about using two double-shots on the Lusso 2-group to make a single latte, which sounds like a reasonable workaround and I don't have a problem doing this, but is the flavour profile of the Lusso more suited to an espresso than a latte?
At my price point neither machine is a perfect fit so I guess I'm looking for the better compromise. I'm leaning a bit towards the Lusso as it is so different to most other machines and I'd really love the spring lever experience, and I think that it is likely to last me longer before upgraditis sets in. But I would hate to spend the money and find that the flavour result is not much of an improvement.
Ideally I would go and try both machines, however the Lusso distributor is in Melbourne (about 900k's away from Sydney) so not so easy to do.
I'm hoping then that you guys with more experience with either (or both) machines can help me out with some advice or suggestions?
thanks in advance!!
Julian
