SigCool wrote:Looking for a single group dual boiler . . . it's between the Vivaldi II or a Livia 90.
Well, if it's between those two, I'd certainly go for the Vivaldi II. The Livia is
not a dual boiler machine; it's a heat exchanger (HX) model.
Things to keep in mind,
IF you want to limit yourself to double boiler machines:
The
La Spaziale Vivaldi II requires a 20 amp plug to perform at its best (but can be run on 15 amps). It also needs to be plumbed in. If the latter is not an option, you will want to look at the
Mini Vivaldi II.
You might also want to look at the
Alex Duetto by Izzo, which is easily convertible from plumbed-in to pourover
and back. It, too, can run on either a 15 amp or 20 amp circuit -- 20 amp is preferable. It's $100 more than the Vivaldi II.
I would also look at both the
plumbed-in OR pourover models of the Vibiemme Double Domo . . . Both require only a 15 amp circuit.
I don't think you can go wrong with
either Chris' Coffee Service or
1st-Line. (No connections, but a satisfied customer of both.)
Of course there are lots of great HX machines out there, too, but that's a different discussion.
Cheers,
Jason
