HB wrote:I don't use the acronym "SBDU" and simply refer to single boilers as well, single boilers; the "dual use" suffix seems unnecessary given there are only a small handful of single boiler / single use designs in existence (e.g.,
La Peppina and
La Caravel).
Yes, well . . . there is -- for lack of a better term -- common terminology, and then there is HB's terminology?
Chris,
- Most people will refer to the design found in a Caravel, Peppina, etc. as an "open boiler design."
- Most people will refer to the design found in a Rancilio Silvia, Gaggia Classic, etc., as a "Single Boiler/Dual Use" design, or "SBDU" for short.
- Most people will refer to the design found in a La Valentina, Bezzera BZ07, etc. as a "Heat Exchanger" design, or "HX" for short.
- Most people will refer to the design found in a La Spaziale Vivaldi II, La Marzocco, etc. as a "Double Boiler" design, or "DB" for short.
In brief, an open boiler design cannot steam milk, as there is no way to build up pressure and produce steam. With an SBDU machine (to use common terminology and avoid confusion), you must wait for the machine to cycle up/cycle down between the brew and steam, steam and brew settings of the single boiler. With an HX machine, cool water is drawn from a built-in reservoir or a water line and is passed through the heat exchanger, where water from the boiler (always at steaming temperature) heats the water "in a flash" to brewing temperature
*. In a DB machine, one boiler is set to brew temperature and the other to steam temperature.
Cheers,
Jason
* This is the same process used, for example, to "flash pasteurize" milk.
