Thinking about buying Quickmill Silvano, any comments??
Postby sherby on Sun Oct 30, 2011 8:16 pm
This is my first posting but I have been reading over the info here and its great. I decided to jump into the espresso world.
This will be my first espresso machine. I have read over the reviews of the silvano and it looks good.
I am looking for a machine that is user friendly, call do espresso and milk drinks also without waiting a while in between. Something that is forgiving for a beginner. From what I read this silvano can do these things. I am going to buy a Baratza vario to go with it.
Are there any other machines in this price range that are similar?
What are the drawback of the Silvano?
Sherby
sherby
Postby EricBNC on Mon Oct 31, 2011 9:06 pm
I picked one up and I am very pleased. I haven't owned enough machines to be able to give you a list of pro's and con's but it makes better espresso than my old Gaggia Coffee (OPV is non adjustable without a mod for that unit).
I still can't quite recreate the shot I had on a LM Strada but I get close enough to think it might be me more than the machine though it is probably a little of both. Close in this case is still light years above what a lot of cheaper machines can create, and maybe closer to the shot a higher price machine can make as well. The 0.7 liter boiler is large enough to give temp stability - especially when controlled by the PID. Add in the extremely easy to adjust OPV and good things can happen.
It looks well built and is heavy enough that it doesn't slide around when I lock or unlock the portafilter but it is not sitting on a very slick surface so this helps. Dry weight is 35 lb but add almost 3 liters of water and the whole thing is probably over 40 pounds. Good luck with your decision. :D
LMWDP #378
Author of "The Bell Curve: Instructions for Proper Herd Mentality"
EricBNC
Postby edsweed on Tue Nov 01, 2011 9:06 am
What about steam power and its ability to make good microfoam?
Ed
edsweed
Postby EricBNC on Tue Nov 01, 2011 5:20 pm
I am not qualified to answer that question since I have only recently tried steaming milk - I can promise it gets milk hot but I have zero steam skills developed as I like straight shots and Americano's.
In this video there is a thorough walk through of the QuickMill Silvano - at a little after the 6 minute mark a steaming demo takes place - in something like 30 seconds the milk is ready.
http://vimeo.com/29008181
LMWDP #378
EricBNC
Postby innermusic on Wed Nov 09, 2011 8:31 pm
I'm happy with my Silvano. On my next upgrade (after I win the lotto), I would look for an e61 grouphead or a machine with the programmable pre-infusion. But there is nothing in the price range of a Silvano which I've seen that does what it does.
innermusic
Return to Buying Advice
