Vince,
Side channeling and spritzing is pretty common with the mypressi, though if it's minimal it shouldn't affect shot quality much. Here are a few tips which should help solve the problem:
1. Use very very freshly roasted coffee. Probably should go without saying. I find the ideal rest time is about 3 days, more for lighter roasts, less for very dark and oily roasts. In any case, the staler the coffee, the less binding you'll have during shots.
2. Downdose and make your grind finer. If you are using 19g for example, try 18g at a finer grind, one that pulls a double in 35 seconds +/- 5 seconds. Personally I find the optimal dose size for a double to be 18-18.5g, but that obviously varies according to roast and taste.
3. Use a toothpick or large paperclip and stir the coffee around vigorously to remove any sign of clumping. In order to avoid having the coffee spill when doing this, try grinding with a funnel inserted in the basket. I cut the bottom out of a Jello pudding cup and that fits perfectly. It works great at keeping all the coffee in the basket both when grinding and stirring.
4. Remove the funnel and then use the "Stockfleth's move" to even out the distribution before tamping. This amounts to little more than running your index finger around the rim of the basket to make the coffee even. Here is a video of the technique, which I think makes a bigger deal out of it than it really is. But it's still useful:
Stockfleths Move for Dummies [video]5. When tamping, start with a roughly 5 lb tamp, then twist the tamper a few times. Inspect the level of the coffee to make sure it is at the same height all around. Then tamp at 20-30 lbs and twist again.
Hopefully this will help get rid of the channeling.
Dom
