Tamper and knockbox - Page 3
Postby takeshi on Tue Jan 19, 2010 11:25 am
CSME9 wrote:I dont know but from the picture the knock box bar across the top doesnt appear to be secured to the round knockbox
As much as I love my Bumper knockbox that's an improvement. It has been a while since I've removed the bar on mine but it's a bit tedious IIRC.
takeshi
Postby Paul_Pratt on Tue Jan 19, 2010 9:47 pm
CSME9 wrote:Thanks Paul.... can you provide (Tubbi) dimensions. I am in the market for a smaller knockbox thats a bit larger than the grindenstein & smaller than the 7x7 sizes.
WS
It's approx. 13cm high at the rear. 9.5cm high at the front. The bar is 11cm accross at the knocking area - i.e. the bit that is inside the tub. I made it so there is clearance for the pf ears.
Footprint is 10cm diam. but it flares up towards the top to around a 13cm diam.
I reckon it can hold about 15 double pucks.
Paul
Paul_Pratt
Postby michaelbenis on Wed Jan 20, 2010 6:43 am
enginerd wrote:I like the mileage received from my Gridenstein, but then again I wanted something a little more petite just for my daily use. Just throwing it out there.
I also have a Grindenstein but find it just a little on the small side to avoid a sprinkling of grinds around its edge, which is why I have been thinking of picking up one of the Cafelat ones for some time... :shock:
Cheers
Mike
LMWDP No. 237
michaelbenis
Postby Whale on Wed Jan 20, 2010 9:04 am
michaelbenis wrote:I also have a Grindenstein but find it just a little on the small side to avoid a sprinkling of grinds around its edge, which is why I have been thinking of picking up one of the Cafelat ones for some time... :shock:
Cheers
Mike
I also have a Grindenstein and find nothing bad to say about it. Looks good, Solid, "quiet", easy to clean,... but it is just a bit small.
My daily consumption is such that I have to empty it too often. What must be understood is that I do not toss the spend grounds in the garbage which would be easy enough. Instead I empty the knockbox outside in a compost pile. So not having to go there every 2-3 days would be nice.
I have been resisting the purchase of a Bumper/Cafelat "Classic" for a while to preserve the little counter space that I am allocated.
Since I am about to succumb to the urge to get a larger knockbox, may I ask the owners of Bumper/Cafelat "Classic" if there is a noise issue with that knockbox. I guess Paul, and the guys at Cafelat, are the only one that can say if the newer knockbox is quieter.
The knocking of the spend box is the single most noisy and disturbing part of my espresso making and I am trying to keep that noise down for obvious reasons.
Hey! I decided not to buy the best available grinder (for the money) just for the noise reason alone. It is that important for me. And yes, I am buying a hand grinder for these early morning and late night grind sessions.
LMWDP #330
Be thankful for the small mercies in life.
Whale
Postby michaelbenis on Wed Jan 20, 2010 11:12 am
Careful there!
My wife prefers the big grinders in the morning - they may make a bit more noise but they do it for a LOT LONGER (less than a couple of seconds on the Nino). She HATES the Lehnatrz hand grinder which cranks on for minutes..... :shock:
In other words, it's not just volume but also time in terms of what disturbs the rest of the family. Bear that in mind! :D
Cheers
Mike
LMWDP No. 237
michaelbenis
Postby Whale on Wed Jan 20, 2010 1:34 pm
I considered it to a degree by a getting a Pe De that grinds a bit faster and a kneemill model where, I would assume, my legs will muffle some of the noise.
Thanks for the warning though. :D
LMWDP #330
Whale
Postby michaelbenis on Sat Jan 23, 2010 4:49 pm
Just got the "classic" Cafelat. Very happy with it. It's twice the price of the Grindenstein but it's more than twice as good. Easier to use and no spatter.....
LMWDP No. 237
michaelbenis
Postby Whale on Sun Jan 24, 2010 7:22 am
michaelbenis wrote:Just got the "classic" Cafelat. Very happy with it.
Thanks Mike. Is there any significant metallic noise coming out of the box? That was my only concern really.
P.S: I missed out on the Pe De grinder because I wasn't around at the end of the auction... Darn these last minute bidders. :?
LMWDP #330
Whale
Postby michaelbenis on Mon Jan 25, 2010 6:28 pm
Whale wrote:Is there any significant metallic noise coming out of the box? That was my only concern really.
Hi Sylvain. The longer bar and thick padding actually makes it slightly quieter than the Grindenstein and the puck falling makes pretty much no noise at all.
The Cafelat is also much easier to use (puck always falls straight past bar and in without having to do anything special, rather than getting stuck as it does on the Grindenstein).
The splash guard at the back works perfectly.
I used to have to empty my Grindenstein at least once a day, this every couple of days.
And the stainless looks nice too. Very well made. No seams.
The Cafelat a very good design well made.
Cheers
Mike
LMWDP No. 237
michaelbenis
Postby Whale on Tue Jan 26, 2010 8:35 am
Thanks again.
I'll order one tonight. The Stainless steel and black fits my setup perfectly. It has been in my wish list for a long time...
LMWDP #330
Whale
PreviousNext
Return to Buying Advice
