In the interest of providing additional information for the Brewtus Steam tip, as I received my machine in December of 2008 and WLL provided me with the replacement single hole tip. I upgraded from the NS Oscar which has a 2.3l boiler and greater steaming ability, I was interested in at least better steaming power than the 1.5mm single hole tip provided from the Brewtus.
WLL happily provided me with several blank tips to experiment with, and to give you some idea of options, here is the calculations I did:
Single hole, 1.5mm = 1.76715mm squared.
Double hole, 2x1.5mm = 3.5343mm squared.
Single hole, 1.0mm = .7854mm squared.
Double hole, 2x1.0mm = 1.5708mm squared.
Triple hole, 3x1.0mm = 2.3562mm squared.
Single hole, .9mm = .63617mm squared.
Double hole, 2x.9mm = 1.27234mm squared.
Triple hole, 3x.9mm = 1.90851mm squared.
As you can see things change drastically with small changes in hole diameter. The double hole 1.5mm tip will deplete the Brewtus boiler rapidly. I found the three hole version @ .9mm worked well so I did not try three holes at 1.0mm (ran out of tips!) but on paper I think it would work out rather well, if someone wanted a bit more power. Math whiz's feel free to correct me if needed!
