mthilen wrote:Hi,
I'm in the process of trying to start an espresso catering company. I was planning on using a Nuova Simonelli Oscar and Mazzer Mini. Would this be a good machine for catering? Any other tips?
Regards,
Max
No and no. You want an espresso machine with larger steam boiler for any commercial application. Nothing worse than having to wait and wait and wait to finish steaming after shot done pulling over and over and over again with a line that doesn't go away for hours. Been there done that with better than Oscar class machine. Now use Brazilia Portofino with 6L steam boiler for catering (and cafe backup), rocks.
You definitely also want direct plumbed machine, use flojet and accumlator when plumbing not available (food grade hose to filter to accumulator) And the Mazzer mini is way too slow, minimum Super Jolly.
IF you already have the units in question you could limp by initially, but I would not go out and buy either for your intended use.
