by dboreham on Mon Jan 24, 2011 4:51 pm
So, this story has taken an amusing twist:
I removed the cover and after 20 min head scratching and consulting the wiring diagram I become convinced that the problem was not with the pressurestat (my machine, it turns out, already has the newer industrial grade 'stat, and it tested ok with ohm meter).
Therefore I set to thinking what could make the machine believe that it has no water. This of course led to the water sensor thing under the tank. So I removed it, thinking it must be some cunning pressure or hall effect type thing, and perhaps was defective.
Imagine my surprise when I find that the screw terminals end in...well.. screws. Oh yes! They are detecting water by measuring its resistance. But every schoolboy knows for sure that pure water is an insulator. Could they be that dumb ?? After some more Google searching I have the answer : yes !
Then the penny drops. The problem was in fact caused by our cats. Read on:
Normally I feed the machine prime Costco 'drinking water' (with minerals added for taste, the small print says). However, for a recent trip away from home my wife had bought a number of large 'drinking water' bottles, to be used by the house-sitter to refill the cats' water dishes (well pump was turned off while we're away as an anti-pipe-freezing precaution). Now, upon our return the cats had not drunk all the water (cats drink puddles, snowmelt, whatever nasty liquid they happen to find on the garage floor, rather than the water you give them..). Therefore I was awarded the large gallon water bottles to be used in the Oscar. After a week or so, it stopped working. This water in fact is reverse osmosis processed, with no added secret sauce, and therefore is a good electrical insulator.
It turns out the Oscar water sensor is a tricky beast. It was unimpressed with tap (well) water. Also not moved by adding some ion concentration to the water (salt). It took the return to prime grade Costco water to persuade it to work again. You also can not trick it by shorting the terminals together (at least I couldn't).
