michaelbenis wrote:Wait.
A Mypressi won't speed things up at all. You wouldn't get much of an improvement in terms of churning out shots even from the much superior (in the cup) Bacchi, which is at least a hands-free solution until the whistle starts.
And if you're getting good shots from your Pavoni, the Nespresso will be quite a disappointment.
Not sure I agree here. With multiple baskets and a water kettle, you should be able to get a system down to churn out shots pretty fast. It's not pretty, but it is low cost. I think the target time for the Bacchi is 6 minutes from the start to when you get the espresso, then you have to cool and reload. With the MyPressi, there shouldn't be any issue with overheating, in fact multiple shots should be ideal as you won't need to pre-heat subsequent shots.
I agree that it's an inelegant solution with a lot of fumbling around with baskets, but it seemed to fit the budget and overcome any issues with overheating (since it's an open kettle with no boiler, you have complete control over the water temperature). One of the other tricks you can use it for at parties is to pull adult espresso drinks using water alternatives which can be fun.
You might consider the Crossland CC1 that is supposed to have improvements in temperature stability and be targeted at the lower end of the scale. I don't have any experience with this machine and have only read reviews.
Overall, I'm very pleased with my Twist. I haven't tried making many back-to-back shots with it, but most of the time I spend with the Twist making a shot is in the boiling of the water, grinding, and cleanup, the time for subsequent shots is very minor.
We have a fancy Nespresso Pro setup here at work with the flying saucer shaped foil Pro capsules instead of the normal pods. These capsules hold 6 grams of coffee so the machine always makes pretty weak espresso with no brightness, citrus, or floral notes (only the same monotone chocolate/hazelnut flavors). I'd rather spend the extra time to pull a shot on my Twist with my own fresh espresso then use the Nespresso machine. The pods/capsules are also pretty pricey, I understand. I briefly played around with
making my own capsules but it really wasn't worth the effort, even though it was fun to try out. The lack of maintenance guidance on the Nespresso offends my sensibilities and I've brought in a group head brush and a wash bottle and try to keep the machine relatively clean for my co-workers, even if I don't bother with the stuff myself.
Let us know what you do choose.
