by Ken Fox on Sat Jan 23, 2010 12:38 am
There are many ways to enjoy coffee and not all of them are expensive. Assuming you already have decent, fresh, already roasted beans, only a tea kettle, a cheap burr grinder, and a plastic Melita filter holder and filter separate you from a nice drink. Similarly, you could use a French press, a $25 Aeropress, or several other methods to produce your cup of coffee, and it could be excellent.
Espresso is a relatively expensive way to prepare coffee; below a certain point what you are making is not espresso but simply "drek." Call it what you want, call it starter espresso, call it mediocre, call it marginally acceptable, but in reality it is NOT espresso. In order to make even low end espresso you need at least an acceptable way to grind the coffee and a way to turn it into espresso.
Telling people that it is fine to go buy some very cheap Breville "espresso" steam toy, combined with a blade grinder (or even worse, pre-ground coffee) is (maybe) going to motivate some people on the margins to see this thing through to where, perhaps, they will get true entry level equipment, which I guess is your point. But I think that is silly. With inadequate equipment they are not really making espresso, they are making a bad version of "strong coffee."
That is not what we are about here. We might not try to get everyone to have "ideal" equipment, but there is a level of equipment that without which one cannot make real espresso. And there is no point in encouraging that approach here, since there are much cheaper ways to make acceptable coffee, if not exactly espresso.
ken
What, me worry?
Alfred E. Neuman, 1955
