by jdbruce on Sun Feb 14, 2010 6:08 pm
I've read all those threads in the past, and just re-read to familiarize myself.
I also looked at the BZ07, and I identified these major differences.
Salvatore:
Black powder coated color (or $100 extra for different colors)
Uses Sirai pressure stat, which is reputed to be the best.
Thermosyphon grouphead
Has Pre-infusion
Lacks adjustable OPV
No vacuum release valve, so you need to bleed the steam when you start it up.
Can't leave it on, have to shut it down if you aren't using it for an hour.
6 year warranty
Uses turning knobs to steam and hot water
Lacks an automatic low-water shut-off
64 oz reservoir
1550 watt heating element
Little shorter, little wider, little less deep (all within 2 inches)
BZ07:
Stainless steel color
Unknown Pressure Stat
Thermostat heated grouphead
No pre-infusion
Has Adjustable OPV
I assume it has a vacuum release valve, so no babysitting.
Not sure how long it can be safely left on.
1 year warranty
Using locking levers to turn on steam (does this mean it's all or nothing in terms of steam output?)
Has automatic low water shut-off
3 liter (100 oz) reservoir
1200 watt heating element.
With those differences in mind, does anyone have any comment? Should I be strongly weighting any of those differences?
I recognize that I won't really go wrong either way, but still...
