Roaster recommendation? - Page 2
- hankua
I like your idea of a Gene or a Quest. The Quest would be my personal choice and would keep an eye out for a used machine. Another one that might suit you is the stainless camp stove roaster; not sure if he is still building them.
Stainless steel manual roaster
- [creative nickname]
In my own opinion, neither the Gene nor the Behmor offer a sufficient level of user control over profiles. Given your interests and your budget, I'd suggest looking into a Quest or a Huky, the pros and cons of which you can read about in great depth on these forums. There are also some newer options coming onto the market -- these may be more of a gamble as you won't have as deep a base of users online to guide you as you learn to use the roaster, but they also offer a few intriguing options at their price points. You can find HB threads about each of these if you search:
Kaldi Wide Roaster (300g, stove-top design): https://www.amazon.com/KALDI-Motorize-I ... 028&sr=1-1
Mercury Roaster (300g, electric): http://www.cloudbean-tech.com/
LMWDP #435
- kschendel
If you want to take a smaller step, maybe get a Freshroast SR500. It's an air roaster, but you can fiddle with the heat levels, fan setting, and cycle the heat manually if you want to slow down a particular phase. It's no Hottop, but it's $170 instead of $1000. I get fairly good results out of mine.
Even if you decide to jump up to a much more expensive drum roaster anyway, having the SR500 around will give you a decent alternative, small-batch roaster without wasting a ton of money.
sounds good. is it durable? will do one or 2 batches every week.
will the quality of the coffee be much different from that produced by a Hottop, Huky or Quest?
The Huky seems powerful; but it seems that dealing with gas is more complicated? do I need to bu a Proban tank and burner? is that economic? how many batches would a standard tank produce?[creative nickname] wrote:In my own opinion, neither the Gene nor the Behmor offer a sufficient level of user control over profiles. Given your interests and your budget, I'd suggest looking into a Quest or a Huky,
ajarmeh104 wrote:The Huky seems powerful; but it seems that dealing with gas is more complicated? do I need to buy a Propane tank and burner? is that economic? how many batches would a standard tank (grill type) produce?
- Sponsor
Since your budget is around 1k, I would think very hard about 2 options:
I went with a used Quest, but there's no option for an automatic roast profile if I get lazy one week. It's always manual. For me, I enjoy it and wouldn't have gotten the HotTop.
- Quest M3
- HotTop
Roasting as little as you are planning to, a standard 20 pound propane tank should last you at least a year.
LMWDP #435
Thanks for the advise.EspressoForge wrote:Since your budget is around 1k, I would think very hard about 2 options:And then decide, if you want more convenience, go with the HotTop, if you want more control and a little better long-term longevity: go Quest.
- Quest M3
- HotTop
But here is the million dollar question: will the better control of the quest result in extra flavor or quality in the cup over the Hottop????
I am not looking to do any Mods(unless if I have to) and not looking to become a professional roast master. All I want is to enjoy a good cup of fresh coffee.... will the Hottop serve me better?
