I thought I would draw on your great collective experience and ask for suggestions for an upgrade from a (non) starter Saeco machine to something better than a Silvia, since everyone seems to appreciate that machine but then upgrades. I've got a Lelit PL53 grinder, so that element's taken care of for now.
So I'm trying to decide between a lever machine and an E61 Hx. I'll probably shop for something used. My espresso consumption is a bit unusual. After reading the posts on espresso and cholesterol, I put the shot through a Melitta filter. This is after testing the idea by trying it at Blue Bottle, where I find the taste very satisfying even after the filtering when drinking their wonderful double ristrettos. The flavor's well-defined and wonderfully intense even after it's used in a soy cappuccino or latte, not to mention a Gibralter (a capp with less milk).
I sometimes like to make cappuccinos. But it's just my wife and me and we don't have many large parties where I'd have to pull many consecutive shots or steam more than two caps.
I've read comments here about clarity of flavors, which I can appreciate when I compare the muddy results at best using Blue Bottle's Hayes Valley espresso on my Saeco versus what they make on their La Marzocco commercial machine, which they can also dose much higher and use lower temperature pre-infusion, etc. I've also read about the forgiving nature of the E61 brew group although am a bit concerned about the power consumption of bringing one of those up to temperature. And I've read that the E61 makes lots of crema and tends to make a sweeter, less defined cup than lever machines. In my case, crema for mouth feel isn't important. I've got access to many blends and single origins in San Francisco, so I'm eager to try different coffee flavors and want decent equipment for this.
What else? I'm thinking of having a machine PID'd to have easier temperature control and do know about temperature surfing. I'm not particular about buying a collector's item, just reasonable price and more consistent and satisfying results, with a thicker, more concentrated result than I can currently achieve. I want to get something where a bottomless portafilter can be purchased in order to refine my technique. I also want a machine with good steaming ability. My current equipment doesn't easily make microfoam. The steam's too "wet" (cold) so the foam is often dry, and I want to experiment with what I've seen in that online steaming video using soap bubbles to improve technique.
What are your recommendations for less expensive lever machines versus a used E61 HX?
This will be interesting. I look forward to learning from you!
