seymour wrote:So I've located a used Silvia, Rocky and base for $550.The owner says it is "a couple years old, retrieved from a pizza shop where people didn't know how to use it". What are the chances that something is wrong with it that will cost a lot to repair? How would I know if something is wrong? Is this too big of a risk for a newbie? Should I just go with the Le'Lit P1043 and Le'Lit grinder (approx. $700) for the safety of a warranty???
Would it be to much trouble to post a pic? If it is a "newer generation" Silvia, then i don't think you should have any big problems. The grouphead gasket might need to be replaced.
What i wrote below here is my experience from not knowing enough, and not asking the right questions. Bad luck of the draw as it seems.
I was in the same position as you a few months ago. I ended up buying a used Silvia, and Rocky Grinder. My used Rocky has so far been a real champ. I replaced the burrs (which was all too easy), and did the teflon tape mod. I am very happy with this purchase.
The Silvia on the other hand has been a total opposite experience for me. All to my own fault. I also bought it used, but i was unaware of how old the unit actually was. The machine was able 8 years old, and as an older model had a few "weaker" design issues. I have since replaced the boiler as it was leaking through the top (new boiler does not have this same design "flaw"). I then had lots of trouble getting dialed in, and my shot quality was sub par. Ended up that the pump was dying. This was a much cheaper fix at $60, but still added hassle. Then the grouphead gasket went. A real cheap fix, and something that needs to be replaced every couple of years.
With the new pump, the new boiler, and the cheap thermostat mod that i did i am pulling fantastic shots almost all of the time. And when i pull a bad shot it is usually my fault, and not Silvia's.
My point here is that if you are going to buy new, ask lots of questions. Age being a question that i did not ask when i bought mine.
I pull two caps each morning for my brother and myself. All in all i am happy with where i currently am, but the journey would have been better had i bought new, or a "newer" used machine.
30mins to warm up - Typically do my morning routine during this time.
15mins roughly to pull two shots and froth enough milk for two caps.
I was much slower when i first started, but it will take you no time to get dialed in to the silvia IMHO.
fyi the cheap thermostat mod is nothing special. It just helps me pull shots a near consistent temperature. I pulled the thermocouple out of a digital thermometer and screwed it under 1 of the screws from the clip holding the thermostats onto the top of the boiler. If warmed up properly, blank shot pulled to warm the cups, the shots i pull seem to be very consistent.
Hope i was of any help.
-Donovan.
