jesawdy wrote:The Quick Mill Alexia machine puts the potential buyer in a bit of a quandary in terms of its price point. In comparison to the ever popular Rancilio Silvia, current machine pricing puts the PID-equipped Alexia at about a $300 premium over a PID-equipped Silvia. The extra cost of the Quickmill Alexia offers:In my experience, the Alexia delivers great coffee more consistently and with less effort than the Rancilio Silvia. It may be hard to justify $300, especially for a budding enthusiast, but let's just say I have not shed a tear for Silvia during the course of this review and I don't relish the thought of going back to "her".
- Infamous E61 grouphead,
- Extra portafilter,
- Bigger boiler and a bigger drip tray,
- Larger pourover reservoir,
- Ergonomic articulated steam wand
At the slightly higher end range of espresso machines, espresso machines like the heat exchanger based Quick Mill Anita come into play. It's not an easy call between the no-brainer brew temperature control of the Alexia without instant steam versus the brew management required by heat exchangers. Alexia's advantages are smaller size, precise control, minimal water usage, and much less temperature management attention required. But, as previously mentioned, the Alexia is best suited to the straight shot espresso drinker. If you and/or your spouse are a daily cappuccino or latte drinker or if you frequently entertain, an HX-based espresso machines would be the better choice, if not a dual boiler machine at a considerable increase in cost.
JimG wrote:I own and use both a PID Silvia and a PID Alexia. So I should be able to answer this question easily, right? Wish that were the case.
The Alexia delivers excellent shots more consistently. And the E-61 group on the Alexia allows a very high degree of confidence that your shot will be within 1F of the target brew temperature (assuming you go with the PID option).
The Alexia's E-61 offers pre-infusion, while the Silvia does not. I have always had good luck with extractions on the Silvia, so it is hard for me to objectively determine how much benefit is gained with the E-61. The best I can offer here is that the Alexia seems to produce, on average, a higher percentage of problem-free extractions.
Were the machines the same price, then the Alexia is a clear winner. And for an espresso purist, a PID Alexia is pretty hard to beat for anything south of $5,000US.
If the choices were PID Silvia vs non-PID Alexia, I would choose the PID Silvia (my company builds and sells PID systems for both of these machines, so I probably can't be very objective on this particular point). Even though the Alexia's stock brew thermostat is adjustable, there is still a temperature cycle to deal with.
A final comment: in terms of improvement per dollar spent, you might also consider investing the price difference between the Silvia and the Alexia in a grinder upgrade.
Jim
jesawdy wrote:Infamous E61 grouphead,
Bellavance wrote:Is Zaffiro the same as Alexia?
Bellavance wrote:Can it be bought with the PID factory installed?
Bellavance wrote:Will the Alexia be happy with Reverse Osmosis treated water?
