Rancilio Silvia to Quickmill Alexia - A real upgrade? - Page 2
Postby Bellavance on Sun Jun 21, 2009 5:01 pm
How does one add minerals to the water?
Pierre
Rancilio Silvia + Auber PID. LeLit PL53 Grinder.
Bellavance
Postby JimG on Sun Jun 21, 2009 5:07 pm
Bellavance wrote:Can it be bought with the PID factory installed?
In the North American market, the Alexia is available "PID-ready." It has a knockout in the front panel sized to accept the controller, and drilled/tapped holes on the machine base for mounting the relay. You can buy an Alexia with the PID already installed, or buy a standalone Alexia PID kit, from Chris' Coffee.
I don't know if the Euro version of the Alexia is similarly configured.
I don't think the Zaffiro is available with these same PID-friendly modifications.
We have helped several customers successfully add PID systems to their Zaffiro's by using a customized version of the Alexia system. But this is not a project I recommend for a novice. Although the installation guide is written for the Alexia, the machines are similar enough that folks with some electrical knowledge can make the necessary interpretations.
Cutting a hole through the face of the machine to accept the controller is definitely not an easy job, so using an external enclosure for the controller is usually preferred.
Jim
JimG
Postby Marshall on Sun Jun 21, 2009 5:17 pm
Bellavance wrote:How does one add minerals to the water?
Like this: http://www.chriscoffee.com/products/home/plumbing/calcitefilter
Also Jim Gallt's PID kits (dealer or self-installed) have an excellent reputation among his customers who post here.
Marshall
Los Angeles
Marshall
Postby HB on Sun Jun 21, 2009 5:22 pm
Bellavance wrote:Will the Alexia be happy with Reverse Osmosis treated water?
Please try searching (e.g., "reverse osmosis") and the FAQs and Favorites before asking questions that may have already been asked/answered several times. Thanks.
Postby Bellavance on Sun Jun 21, 2009 7:05 pm
RE: Reverse Osmosis water.
My RO water has a TDS of 4, so I guess I'll start using spring water in my old Silvia.
Pierre
Bellavance
Postby HB on Sun Jun 21, 2009 8:01 pm
Bellavance wrote:My grinder is a LeLit PL53. Is it good enough?
For the benefit of those following this thread and to avoid needless repetition, refer to the related threads that Pierre started on CoffeeGeek here and HB here.
Postby sweaner on Sun Jun 21, 2009 9:50 pm
Dan, would you please stop repeating yourself! :wink:
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby Bellavance on Tue Jun 23, 2009 7:49 pm
On the Coffee Geek Forum, I was told: A Grinder improvement will show much more results in the cup then a machine improvement.
Does this mean that upgrading from my LeLit PL53 grinder to a better grinder will give me better coffee than upgrading from my Silvia to an Alexia, while keeping my grinder?
Can this be true ? !!
Pierre
Bellavance
Postby HB on Tue Jun 23, 2009 7:58 pm
Bellavance wrote:Does this mean that upgrading from my LeLit PL53 grinder to a better grinder will give me better coffee than upgrading from my Silvia to an Alexia, while keeping my grinder?
No, in terms of grind quality, you're already in good shape. Jim's Can it Beat the Mazzer Robur? provides one man's informative and entertaining read on the subject. For those who wish to skip ahead, see Tale of the Tape: Mazzer Robur vs. Nemox Lux, which has the same burrs as the PL53.
PS: Your cross-posting of each of your questions is getting tedious (link). Please pick one site per thread, and I won't be offended in the least if it's not here. Thanks.
Postby pravspresso on Sun Aug 02, 2009 9:40 pm
FYI.
I've had the Alexia w/pid for about 6 months now. I had a PID gaggia classic with other mod's before.
I'm using the Rancilio Rocky grinder. The shots have been absolutely amazing.
The machine caught me off guard (sound) when i first started using it... it was very quiet in comparison to my friends Silvia as well as my old Classic. I have noticed the drip tray is enormous and well made for
easy removal and cleaning.
The price is very high in comparison to the Silvia (agreed).
I decided to spring for the extra cash & go for some bling factor with the Alexia (looks fantastic in the kitchen). The tactile feel of lifting the lever to activate the brew cycle has a nostalgic effect IMO ;).
I've also been able to brew multiple shots in a row for guests without any lag time for the water to get
back to a proper even temp. You may have to wait a bit longer with the silvia. Serving guests
is no longer an issue because the boiler is very temp. stable. I agree with the previous statement
that this machine is really meant for straight espresso shots. If i had to pull a shot and then steam
milk for each drink i made it would be a real hassle. With a espresso driven machine such as this i pull
all my shots first and then steam milk afterward.
Hope this helps.
pravspresso
Previous
Return to Buying Advice
