by Beezer on Thu Mar 29, 2007 4:28 pm
Wow, Tim, sounds like you and I are on a similar path. I just upgraded from a Gaggia Classic and Rocky Doserless to a Quickmill Anita and Macap M4.
As far as which machine to buy, I'm somewhat biased but I think the Anita is the best deal for the money. Having the convenience of brewing and steaming back to back is a real blessing. If you get a PID'd Alexia, you'll get great shots but steaming will be painful. I thought that doing cooling flushes would be a hassle, but it's really no big deal. My shots started out OK but not great, but I was having some trouble with distribution and tamping leading to channeling. The machine's OPV is also set a bit high at 10 bar, so I'm going to lower it a bit. But even so, my shots have already improved a great deal just by paying more attention to dosing and distribution.
Steaming without any delays and having ample steam for a big pitcher of milk have also been very nice perks. My microfoam is better than ever with the new machine. It's creamier and seems to float on the surface of the crema much better than before, and I never run out of steam in mid-pitcher like I used to with the Gaggia. Very sweet. Also, you should note that the newer Anitas now have swiveling steam and hot water wands, so they're very easy to use. The old ones would swing up and down, but not side to side.
The only complaint I have so far is that I have to refill the water reservoir pretty often, maybe every other day. I can see how having a plumbed in machine would be a real advantage just so you don't need to constantly refill that reservoir. But I couldn't do plumb in since we just got granite counters, so I have to live with having a pourover. Even so, it's really no big deal. I haven't had the machine run out of water during a shot yet. Knock on wood.
Given your current choices (Alexia, Anita, Vetrano), the Vetrano is clearly the nicest with the rotary pump and plumb in features, but it is almost $500 more than the Anita. The Alexia with the PID is almost the same price as the Anita, but lacks the convenience of the HX for steaming milk drinks. So I think the best deal is the Anita. Alternatively, there's also the Bezzera BZ02S or the Expobar Pulser for about $800. I nearly got the Bezzera, but my wife liked the shiny look of the Anita more. From what I hear, the Bezzera is a great machine for the money.
Good luck with your search.
Eli
