BIKERBOB wrote:I would like your thoughts on the following machines as an upgrade; there are features I like on both
First the Expobar Office Control; like the idea of programmed shots; concerned about temperature stability (currently have a Solis sl90 which has this programmed shots) Expobar is $1300 cdn
Second the Quickmill Alexia; like pid option of temp control and the e61 group. Quickmill is $1400 cdn plus 320 for the pid option unsure if I would like making shots manually (not sure I can justify the added cash)
Is anyone aware if the Expobar can be fitted with a pid, and who could supply the necessary equipment and know how?
Thank you and again I await your thoughts
Like offerings from Quickmill, Vibiemme, Isomac, etc, the Expobar Control is a heat exchanger espresso machine based on the popular E61 group. I haven't read it closely, but this review on CoffeeGeek for the similar Office model seems fair. The Quickmill Alexia is a single boiler and is reviewed on this site here; it's a great "espresso purist" choice. I've tried it with and without the PID control; personally I think it's a must-have option since temperature surfing gets tedious quickly.
Since the Expobar Control and Office are heat exchangers, there's no point in fitting them with a PID temperature control for the steam boiler; PID on a HX...this is my thinking, is it flawed? explains why. To be fair, you could go with a PID if you adopt Ian's hybrid approach documented in HX Heaven or 1½ Boiler, but most people weighing the HX/PID option decide on a double boiler instead.
PS: I merged your new thread on the same subject with your previous one; keeping your buying discussion in one thread helps others follow your decision making process.
