lattelover wrote:...split from Some thoughts on heat exchanger vs. double boiler espresso machines by moderator...
I was ready to pursue buying a double boiler because of the milk frothing/steaming capability and lower learning curve, but then I read a blog by Kat at Seattle Coffee Gear dated 3-1-09, around the same time that this forum discussion began, and also I talked with her on the phone yesterday. She said that the Italian espresso machine makers stopped making double boilers for commercial use in the 1970's and since then have been making them only for home use. Also, she talked about the "dead" water, or residual, that sits in the double boiler until the next batch, whereas the heat exchanger is constantly cycling fresh water through the siphoning system. This is not the same as having spring water sitting in plastic jugs, because the water can or does interact with the boiler. The link to her blog is below. Of note, Seattle Coffee Gear sells both kinds of machines, with the idea that there's a home for each.
I'd appreciate any comments anyone can offer.
Ann
A lot of science and techno-expertise here! I'm impressed with Ian's "cheap and cheerful" TDS testing and the other helpful info. on descaling, leaching, etc.
Also, thank you, John, for clearing up the "cross posting" issue. Hope you know I was speaking tongue in cheek about the "kinky" stuff. In the end, I missed what you meant completely, so good to have it straightened out.
With regard to the equipment, two aspects are sticking out for me:
1) COPPER: Newbie though I am, I do feel concerned about the copper boiler/copper tubing issue. Where I live we have very hard water, a water softening system is required, and the plumbing in the area is generally being switched over from copper pipes to something like PVC because the copper deteriorated over time due to the hard water, maybe even with softeners. However, it looks like it's hard to get completely away from copper in espresso machines because even if the boilers are stainless, the tubing seems to be mostly copper.
2) SMALLER BREW BOILER CAPACITY: I don't know how easy it is to empty the brew boiler when not brewing, for the purpose of putting in fresh water, and I also don't know how much of an effort it is to fill it if it runs dry in mid-brew. If neither of those is a major effort, then I would think the smaller capacity brew boiler would be a good idea because the water is being changed often enough.
Right now, I'm leaning toward double boiler machines rather than HX. The GS 3 and Synesso are out of my price league, so I'm considering the Mini Vivaldi II (group boiler 0.4L) or Alex Duetto (group boiler 0.8L). The Duetto has stainless steel boilers but copper tubing. I don't know what the Mini VII has.
Any comments are welcome!
